B BigRich954 Joined Aug 13, 2009 Messages 148 Location nj Jun 23, 2020 #1 What's the deal with it better quality is it just a multi-purpose
L Linctex Joined Dec 31, 2016 Messages 10,144 Location Waco, TX Jun 24, 2020 #2 Completely different formulations and properties anti-foaming agents anti-wear additives anti-corrosion additives etc. etc. etc.
B BigRich954 Thread starter Joined Aug 13, 2009 Messages 148 Location nj Jun 25, 2020 #3 That wasn't much help. Why carry different weights if one can cover all ? Is there any downside to using this weight ?
MolaKule Staff member Joined Jun 5, 2002 Messages 24,029 Location Iowegia - USA Jun 27, 2020 #4 Originally Posted by BigRich954 What's the deal with it better quality is it just a multi-purpose What Brand are you referring to? Do you have a link?
B BigRich954 Thread starter Joined Aug 13, 2009 Messages 148 Location nj Jun 27, 2020 #5 its just the orellys brand i wanted to get one hyd fluid to use in dump trailer dump trucks other small systems
MolaKule Staff member Joined Jun 5, 2002 Messages 24,029 Location Iowegia - USA Jun 27, 2020 #6 That means it has an equivalent 0W30 rating and most likely contains a lot of Viscosity Index Improver. https://www.bobistheoilguy.com/viscosity-charts/ Consider this oil in ISO 68 grade: https://www.schaefferoil.com/documents/130-254-td.pdf Last edited: Jun 27, 2020
DriveHard Joined Nov 24, 2003 Messages 3,791 Location Middle of Iowa Jul 23, 2020 #7 as a hydraulics engineer, I would steer you away from multi-grade oils...pumps/motors/valves are very tough on VI's Pick the proper viscosity for the temperature range and equipment you are using...happy to help if you can answer some questions.
