Sounds more like an equipment issue than fuel, equally I've also had 0 issues whenever I used it.Subscribed. I just bought two new cans for my OPE and would like to know as well. ive had zero issues with it so far, but have also read that people are having trouble rev’ing out to max RPM or something.
If the equipment runs poorly on a tank of fuel, but that fuel is dumped out and a different batch of fuel is poured in that causes it to run normally, the issue is the fuel.Sounds more like an equipment issue than fuel, equally I've also had 0 issues whenever I used it.
Ideally yes but believing people on Youtube is a problem in itself.If the equipment runs poorly on a tank of fuel, but that fuel is dumped out and a different batch of fuel is poured in that causes it to run normally, the issue is the fuel.
Pre-mixed canned fuel you buy off the shelf at a store.what is Tru Fuel ?
I've seen those chickanic videos and I don't doubt that there are occasional issues with the fuel. I bet all the fuels have issues from time to time but trufuel probably outsells the other fuels by a wide margin. I will say I used it for 10 years on my trimmer and it always started even after sitting for 2+ years. You can run worse things through your equipment. I don't use canned fuel anymore because I have more than one 2 cycle engine and it just makes more sense to mix my own as I have E0 available close by.
OK, I've seen that stuff. quart sized cans of pre mix for 2 stroke equipment.Pre-mixed canned fuel you buy off the shelf at a store.
Yup, this is exactly what I practice and recommend to my small engine customers, especially for 2 stroke machines I use very rarely.I generally mix a gallon of e10, with the oil and a little Stabil.
if I don't use the mix in a reasonable amount of time I dump it in the cars
and mix some new fuel with oil.
I also always drain any unused fuel from 2 cycle equipment and then run the engine until it quits before storage.
If you only use a qt in a year, it's super convenient.OK, I've seen that stuff. quart sized cans of pre mix for 2 stroke equipment.
never did see the point of it..
but if the stuff has QC problems my guess would be shelf life.
other guess would be someone blaming the fuel when it is really the piece of equipment..
TruFuel is mostly Naphtha. The engine will not run as well on TruFuel as it does on gasoline.What are the complaints (according to some internet experts) about why Trufuel is bad for your OPE?
AVGAS is WAY better than TruFuel. It is actually gasoline. It does not need any stabilizer additive. AVGAS will last at least 5 years (some experts claim 10 years) if stored in an airtight metal or glass container (at least 2 years in a fuel tank or plastic container). Even after it gets old, it only loses some volatility and does not varnish.Price.... I get 94ul or 100ll from a local airport. keep the container closed and they are stable for at least 2 years.
