should I go OEM BMW or Walmart I'm leaning towards Excide since it's the OEM for BMW batteries.
I saw in one of your other threads that you have a costco membership. Their return policy can't be beat
Isn't it just a 3-year return policy on batteries? Or is it technically lifetime?I saw in one of your other threads that you have a costco membership. Their return policy can't be beat
Do exide batteries not last long?I wouldn't get Exide, I'd get JCI/Clarios. The longest warranty out there is probably Pepboys. Their Champion is 4 years, other places like Autozone, Advance Auto are 3 years. I think Costco is either Interstate or Kirkland, but it's still just 3 years. Check the voltage with a meter, probably nothing wrong with it.
Aren't you supposed to turn lights on first for a few seconds to remove surface charge before measuring?It could be that my 2 cheap/free HF multimeter each read a tiny bit low at 12.4v-12.5v after a decent amount of time(4 hrs) on a maintainer, and showing full charge(Green Light).
When I test the batteries about an hour after removing the maintainer BUT without opening the doors to pop the hood and just keeping the hoop unlatched. I'll put the multimeter right on the battery posts to test them, this 12.4v-12.5v is what I get.
Good question. I would have confidence in a BatteryTender, BatteryMinder, and other name brands.How do I know if it's legit? I paid $20for it on amazon. So, it's probably bs
IDK!Aren't you supposed to turn lights on first for a few seconds to remove surface charge before measuring?
That's just parasitic drain which is very small - it may or may not remove surface charge. From what I understand, you need a little bit of higher load, like from headlights, to remove surface charge. Maybe someone else will chime in.I figured that, after after an hour of removing the maintainer, I'll check the battery voltage(clock & computer memory operating) that the voltage reading should be accurate? I mean, there is always something running/operating in a vehicle, correct? Wouldn't this remove the surface charge as you mentioned?
Surface Charge
Lead acid batteries are sluggish and cannot convert lead sulfate to lead and lead dioxide quickly during charge. This delayed action causes most of the charge activities to occur on the plate surfaces, resulting in an elevated state-of-charge (SoC) on the outside.
A battery with surface charge has a slightly elevated voltage and gives a false voltage-based SoC reading. To normalize the condition, switch on electrical loads to remove about 1 percent of the battery’s capacity or allow the battery to rest for a few hours. Turning on the headlights for a few minutes will do this. Surface charge is not a battery defect but a reversible condition.
Of the 3 battery makers, Exide is considered the worst. East Penn/Deka is well liked, but they're small volume. JCI/Clarios is the other major one and they also make a majority of batteries. Bosch is about the only AGM brand that I know is Exide. Pepboys used to carry them and they got rid of them so it was hard to get them to honor their warranty if they didn't even carry the battery in stock anymore.Do exide batteries not last long?
Did you pick up a volt meter while you were there? A cheap basic one is only $10-$20.Update: I just had the battery tested at two different auto stores. Advance auto and autozone. Battery came out good. 100% charged
I found my dads volt meter so I’ll let the battery sit for a day and check the volts.Did you pick up a volt meter while you were there? A cheap basic one is only $10-$20.
...I’m working on a 2012 BMW X5 xDrive35i. The customer brought the vehicle to our shop complaining of a slow cranking problem, so we tested the battery and determined that it needed to be replaced. Our normal policy is to install a memory-saver in the OBD II diagnostic connector before disconnecting or replacing a battery on any vehicle. That’s what we did while installing a new AGM in the BMW, but things didn’t turn out so well.
With the new battery installed, I got ready to register it and discovered some problems that didn’t exist before the old battery was removed. The windshield wipers couldn’t be turned off, nothing could be changed on the center instrument cluster screen and my scanner would not communicate with the vehicle. Fortunately, the engine would still start and stay running. It was going to take some time to sort this one out, so we gave the customer a ride home...
...BMWs are equipped with more control modules and other electronic components than vehicles from just about any other manufacturer. They’re heavy users of electricity and there’s an awful lot that goes on behind the scenes each time the key is turned to the OFF position. Battery health, always important on a late-model vehicle, is especially important on BMWs. I believe in your case current was back-feeding through the wiring harness from the memory saver, placing a higher- than-normal current demand on some of the circuits that are directly or indirectly linked to the diagnostic connector. All it would take would be one module activating or some other electrical activity to take out the 5A fuse at position 134. Be thankful that nothing more serious occurred....
Nope, not that I know of. I've never changed the battery in my BMW yet. The previous owner had it changed by his BMW mechanic in 2016.Is your BMW fussy about battery changes?
'Bright Idea' For Short Detection | MOTOR
The Law of Unintended Consequences I’m working on a 2012 BMW X5 xDrive35i. The customer brought the vehicle to our shop complaining of a slow cranking problem, so we tested the battery and determined that it needed to be replaced. Our normal policy is to install a memory-saver in the OBD II...www.motor.com
