Originally Posted By: Max_Wander
it just looks to me like Honda/Acura just arbitrarily chose a test based on a characteristic where Mobil 1 stands out, in this case volatility and burn off. Then they made up a spec that singled out only the characteristic of their marketing partner, ExxonMobil's product and put it up against clearly inferior nameless competitor products.
The test focuses on turbocharger deposits, not volatility and burn-off. Honda came out with the spec. for their turbocharged engines and did not feel comfortable with recommending just ILSAC GF-4 or API SM specs.
I see. How are volatility and burnoff not related to turbocharger oil coking?
Turbo deposits are from oxidation, nitration, polymerization, and any other of the detrimental chemical reactions and/or insufficient detergency/dispersancy. Volatility is a phase change from liquid to gas. High volatility could trigger deposits if a gas bubble forms and then the thin film remaining gets cooked but I don't know if that ever or generally happens. That is an indirect effect while chemistry has a direct effect. What I'm getting at is you could have a high viscosity, low volatility oil that cokes up like crazy and vice-versa. By the way, Mobil 1 5w30 does NOT have great (low) volatility.
