Originally Posted by ram_man
I've read several things that g070 is too thin and increases wear
Any proof associated with the things you've read, aside from speculation? Do you need "better" wear protection? Is your car tuned? Do you race it?
Don't put too much stock in the VW forums. Most don't know their [censored] from a hole in the ground, and will tell you to run Liqui Moly because "it's the best."
The VW oil will protect well, give you buttery smooth shifting, and cost less than anything else.
2L will do it.
