What to do with 15 litres of "personal lube"
'Stralia
Unique position today, after 16 years as an engineer.
People were using petroleum jelly for a plant related job in our cooling water systems. Not really good for the plant.
I ended up purchasing 15 litres of personal lubricant (animal grade
Can't wait for the thought police to track my internet activity researching "water soluble lubricants", and ultimately arrive at my purchase requisition.
Make a large donation to the local zoo. Maybe they will put up one of those plaques for you - "Welcome to the zoo Mating Pen, funded courtesy of Shannow".
Oh, by the way, why DID you buy 15L of animal lube?
What did you get, glycerin? And is there any fragrance or aloe or anything added?
As I understand it, that stuff is a byproduct of biodiesel... too bad Bio-T is on the other side of the planet.
We've got some leaks on the steam condenser, with cooling water getting into the steam space.
The fitters place plastic sheets over the tubes at one end, and move a candle around the other end. When the flame gets sucked into a tube, that's the one that they plug.
Given the small size of the leaks, they were using petroleum jelly to form a better seal on the plastic. It worked but 20Kg of petroleum Jelly (they have to check 17,000 tubes) is a bit too much to be releasing into the cooling circuit.
Thus the need for something water soluble.
Pay to have it shipped home, even it ends up costing more than the purchase price. No way would I risk getting pulled over or involved in an accident [with a news van]
Well, you learn something everyday. When we couldn't just hit a slight amount of steam to the hex and have the offending tube puke out a geiser of vapor, we hired some guy with a "professional" leakdown tester". It took a while, naturally. With two primary exchangers (small) with 200 tubes each ..it was time consuming.
Gary,
the condensers operate at 6kPa absolute on the steam side, and we can take a half (waterside only) out of service.
The vaccuum leak draws the flame in.
Other techniques that we use are flooding (only out of service, so we don't get much opportunity), or gettinga contractor in to spry SF6 around and monitor the exhaust for gas.
