Which of the following is the most important in creating the least amount of wear in an engine, assuming all are changed using reasonable intervals.
1. The OIL itself. (type, grade, etc.)
2. The OIL FILTER. (filter's which filter at the smallest
micron levels would be better at
trapping the "dirt" that causes wear
that others would miss.)
3. The AIR FILTER. (good filtration is the key to keeping
silicon levels down to create less wear.
Let the debate begin.
