- Joined
- Nov 29, 2009
- Messages
- 7,441
Do you lose hvac everytime you stop?
They just use an electric motor to run the compressor much like your home AC.Do you lose hvac everytime you stop?
So it's just a separate motor that turns on everytime you turn on the ac?They just use an electric motor to run the compressor much like your home AC.
You got it, Pontiac!So it's just a separate motor that turns on everytime you turn on the ac?
Also of note they use a unique oil, not regular PAG oil. Ford uses a POE oil in their systems.
In cars with start stop buttons. Does the air conditioning turn off when the car comes to a stop?Do you lose hvac everytime you stop?
My antique Insight did, the assumption was that the fan over the cold AC coils was good enough to keep you cool the <5 min you are normally stopped.In cars with start stop buttons. Does the air conditioning turn off when the car comes to a stop?
In my ford, the fan will gradually ramp speed down so that there is air moving, but as the coil starts to warm the fan slows so it’s still blowing something cool. It starts about 5 seconds after you think your comfort-sensitive spouse has started biting her tongue but doesn’t say anything. It varies the rate and timing based on who-knows-what…. Interior temp? Exterior temp? So the timing varies much but the 5 second rule is always spot-on. Good math, whoever figured it out.In cars with start stop buttons. Does the air conditioning turn off when the car comes to a stop?
Kind of. The compressor doesn't continue to turn on my VW, so you feel the air get a bit warmer out of the vent if the car decides to shut the engine down.In cars with start stop buttons. Does the air conditioning turn off when the car comes to a stop?
lmaoIn my ford, the fan will gradually ramp speed down so that there is air moving, but as the coil starts to warm the fan slows so it’s still blowing something cool. It starts about 5 seconds after you think your comfort-sensitive spouse has started biting her tongue but doesn’t say anything. It varies the rate and timing based on who-knows-what…. Interior temp? Exterior temp? So the timing varies much but the 5 second rule is always spot-on. Good math, whoever figured it out.
I put a paper clip in the a/ss switch and avoid that anxiety now.
You'll have to explain the paper clip thing. Is there a process to bypass the auto start stop by using the paperclip as a jumper?In my ford, the fan will gradually ramp speed down so that there is air moving, but as the coil starts to warm the fan slows so it’s still blowing something cool. It starts about 5 seconds after you think your comfort-sensitive spouse has started biting her tongue but doesn’t say anything. It varies the rate and timing based on who-knows-what…. Interior temp? Exterior temp? So the timing varies much but the 5 second rule is always spot-on. Good math, whoever figured it out.
And the disadvantage is the much higher cost. Compressor for my Leaf at the dealer is $1400.The advantage of an electric motor driven AC also allows for the system to be "right sized" instead of oversized to accommodate a car's variable engine speed
