As the title says, what would y’all use for a high mileage engine? What do you think the best is?
Depends...what engine, what is high mileage, does it leak or burn oil...we need details
Is it leaking oil ? Is it burning oil ?As the title says, what would y’all use for a high mileage engine? What do you think the best is?
In my case it’s a vortec 4.2, 137k miles, no leaks. I was asking in general though.
Is it an LS engine ? If so , it is not that high a mileage . I drove a company truck that was totaled around 160,000 miles . Another one that starts making clicking noises when the temperature got down to 32F and below , on cold start . Noise went away when the truck warmed up ?In my case it’s a vortec 4.2, 137k miles, no leaks. I was asking in general though.
That’s middle mileage in my book...In my case it’s a vortec 4.2, 137k miles, no leaks. I was asking in general though.
Im at 360,000 and never used a high mileage oil yet. My understanding was oils break down and varnish and seals give out? How much seal additive is in non hm oil? I was told that Redline was once used as a hm oil. But more important was that all oils have seal conditioners,right? So is a hm oil just a slightly higher additive package? Seems if its more in a general III oil that more is better if its the same moniesI have never understood the thought of using HM oils only after leaks are detected. IMO, I want the HM seal conditioners at work before any leaks might occour. The seal swellers are most effective if used preemptivly, again, JMO.
