OVERKILL
$100 Site Donor 2021
Originally Posted By: scoobie
How come you always throw a wet blanket over all of my newly discovered revelations: I really enjoy finding out all these new things about motor oil from the experts on the internets, and Dr. Haas says that you should try the oil out, and decide for yourself, after careful study of the published properties, and review of the literature.
Because your revelations seem to be only a partial understanding and then you go off on a posting rampage posting only half-factual information and doing so as though the information is completely correct.
Calling engine designers idiots based on ONE PERSON'S theories and observations is ludicrous, and flies in the face of decades of research, design and testing performed by the manufactures of the engines in question.
I am not coming down on Dr. Haas's information; far from it. He has done his studies and conducted his testing and has observed certain results based on this (limited) testing that shows that under MODERATE driving conditions, in SOME engines, that a thinner oil SEEMS to (in the short-term thus far) yield better results than the factory-recommended oil. I do not believe he has done any actual tear-down testing/validation.
Ford's switch in the modular family to the 5w20 weight very much supports part of his theory.
On the other hand, Ford NOT back-spec'ing certain engine families to the 20-weight should be noted, as it was obviously done for a reason, and the engineer(s) that made that decision/recommendation were doing so based on data that none of us have access to, but likely cover a large sample of engines tested in a manner that showed an anomaly with the thinner oil, thus preventing them from recommending it for that application.
As with everything you read and learn, the absorption of the information is only part of the equation. Understanding, and then determining application and HOW the application of the data is applied are equally as important as the information itself. Regurgitating data without fully understanding simply does a disservice to you and the people you present it to.
There are a couple of Tribiologists on this board; MolaKule and Terry Dyson. Do you think that, being experts in their field that they always agree with each other? How about always agreeing with Dr. Haas?
