What oil has the most ZDDP?
Sarasota, FL
So.. What non-racing oils have the highest ZDDP?
How much does GC, Mobil1 5W30 EP, and Amsoil S.S. 0W30 have?
Just wondering if I have the right stuff in my crankcase?
Amsoil SSO 0w30 would have the most. I can't remember what the exact number is but I believe it is in the 1000 - 1100ppm.
I use this oil in the winters and it is superb.
Originally Posted By: Pablo
The oils mentioned don't have particularly/relatively high ZDDP compared to HDEO's.
Which engine and car are we talking about?
04 SE-R Spec-V
Originally Posted By: chevrofreak
Rotella 10w30 is an HDEO.
I should have been a tad more specific...the oils the OP mentioned
04 SE-R Spec-V
I would say the three oils you list will be just fine and no undue wear will occur due to lack of ZDDP.
Mr. Widetires
Understand that the zinc, bound in a zinc phosphate compound, is not THE ingredient for a robust oil. Oils are a combination of ingredients. The ZDDP compound is just the cheapest highly effective antiwear and antioxidant agent. Reduced zinc levels plus other ingredients do a fine job. Some old engines, especially if they have especially high pressure on the valve train parts due to high performance parts substitutions, require more antiwear and antiscuffing agents than modern oils, but this is very few engines, and probably no modern engines.
The lowest cost way to get a very robust oil that is also high zinc is to use one of the 10w30 or 5W-40 dual-rated diesel & gasoline engine oils. Buy whichever you find first...they're all very good.
