Originally Posted By: Craig in Canada
Originally Posted By: ben_321
thanks for the replies i will look into the oils, i will look for the castrol European 0w-30 or the mobil 1 0w-40....i havent seen ethier oil anywhere
i was also considering just running the BMW dealership oil which is 5w-30 synthetic (group 3 oil i believe) but it is on the very heavy end of the scale for a 30 weight oil, thats why most people run 40 weight oils becasue it gets the viscosity closer to the BMW spec.
Anything which should be in the M52/M52TU/M54 series is heavy. GC 0W30 and BMW 5W30 are nearly 40s, which is where they need to be (in general) to earn ACEA A3. At least at one point GC was the only 0W30 to earn ACEA A3. You should also know that M1 0W40 starts thicker in the bottle than GC (14.1 vs. 12.1) but very quickly shears into the 11s which GC stays relatively stable in the low 12s.
You should be able to find GC at Canadian Tire, PartSource and Walmart. You should be able to find M1 0W40 all over the place, including Canadian Tire I believe. Canadian tire often runs 25% off Castrol sales (2-3 times per year). You could stock up on GC when they have a sale on.
ill check at Canadain tirea and wal-mart later see what i can find thanks!,
on a new topic anyone have any ideas for Transmission oil (Manual) and for the rear diff (not an LSD)
i was thinking of getting a bottle of BMW MTL-LT-2 but apparently its really hard to find at the stealership as its considered "lifetime fill
" so they usaully only have a bucket of it for repairs.
i think im going to Use royal purple syncromax as it worked great in my Jeeps notchy shifting 5 speed and ive heard good results about it on other BMW's....
i guess i will go with RP max gear for the rear diff most liley is the 75w-90 flavor....
