What oil do you recommend ?
Originally Posted by Triple_Se7en
Originally Posted by tiger862
I have them bring it to me. Everyone has their own brand and if I recommended something else it goes in one ear and out of the other. If they want I will get correct spec oil either Napa or Valvoline
Good thought / idea. That way there's no argument if something goes awry with an oil brand you recommended.
Let the blame fall on the vehicle owner's recommendation.
That's why I ask a couple of questions..to avoid this,
Me: "hey, how's that oil working out for ya?"
Them: "I dumped it, it didn't do anything for the leak"
Me: "What leak?"
Them: "Yeah, I've had a small leak so I ended up going with Mobil 1 High Mileage and it seems to be working"
Me: "Oh, you never said you had a leak.."
Them: "You never asked.."
Originally Posted by BLND1
Say "hey, yeah that's a good one." .
That's an important step
Originally Posted by tig1
Mobil 1 oils have served my engines very well since 1978. All engines have remained very clean, none have shown engine wear, not one engine has ever increased in oil consumption over the time I owned the vehicle, and some with with well over 200-350K. All at 10K OCIs.
Yep, can't go wrong with Mobil 1, you always know it's a good well formulated oil.
The only reason I don't recommend it in Australia is because of price, about $100 for 5L. You can spend less than half that and still get a good oil here.
Have they changed the formulation recently? In a Facebook truck forum I belong to someone that seems knowledgeable claims the formulation is not as stout as it once was and there are better choices like ls30 and Schaeffer 9000.
There are Walmarts in currently very hot Down Under?
No to Walmart, Yes to very hot.
If it's a European car I usually go Shell Helix Ultra:
mid-SAPS ECT 5W30 (C3, BMW LL-04, MB 229.51)
full-SAPS 5W40 (A3/B4, BMW LL-01, MB 229.5)
Unless it's an Audi / VW then it's Nulon European 5W30 with VW 504/507
This stuff is also easy to find and reasonably priced (for Australia)
Originally Posted by RDY4WAR
Havoline Syn-Blend High Mileage in the 6 quart box. Cheap and easy.
Great choice, I wish we got that here
Three good Castrol Magnatec oils that serve most here are
Magnatec "Stop-Start" 5W30 (API SN/CF, ACEA A3/B4)
Magnatec "Fuel-Saver DX" 5W30 (API SN-Plus, ILSAC GF-5, Dexos1-Gen2)
Magnatec "Diesel DX" 5W40 (API SN/CF, ACEA C3, Dexos2)
All are full synthetic.
Just today, coworker asked me if Harvest King oil is any good. I said yeah, it's fine for a normal car. He said what about for my truck?
He drives a 500+ horsepower Roush supercharged F-150.
My response was;
Why are you putting $13 oil in that truck?
He said ok. I'll just stick to Valvoline.
That's what's in the sump right now.ðŸ‘..RGT's on deck for February.
Yeah, Rotella Gas Truck, that is another great oil you guys have that we don't get over here.
However we do get this new full synthetic Magnatec "SUV" 5W30 that is API SN/CF, ACEA C3, MB 229.51 and Dexos2 which comes in a big 7L jug. Many people are going light duty diesel these days that require a mid-SAPS C3 style oil and have a larger sump.
Would that be an oil salesman?
SR5
Your down-under oils are a little different.
I think the full synthetic Magnatec 5w30 flavor here is SN Plus / Dexos1 Gen2.
.... or maybe things have changed and I'm wrong.
SR5
Hi T7,
Yes I think you are correct, I've listed most of the full synthetic Castrol Magnatec and Valvoline SynPower oils below. Here we seem to go for a diversity of specification and approvals.
I like that, as a formula can be a bit more optimised that way. For example API & ILSAC are more restrictive on Phos (and hence ZDDP) levels than ACEA A5/B5 or Ford 913-D. This allows me to select a resource conserving 5W30 that is either low-ZDDP & GF-5 / Dexos1 or high-ZDDP & A5 / Ford 913-D.
If someone wants a thin 5W30 they get SN & GF-5, if they want a thick and high TBN 5W30 they get SN & A3/B4, if they want a thick and mid-SAPS 5W30 they get SN & C3.
The thing is this diversity is all available at the local auto-stores. Then you get the thick and heavy Penrite range of oils which is even more diverse.
Cheers and Merry Christmas,
SR5
Some Australian full synthetic oils
Magnatec "SUV" 5W30 ( API SN/CF, ACEA C3, MB 229.51 and Dexos2 )
Magnatec 5W40 (API SN/CF, ACEA A3/B4)
Magnatec 0W20 (API SN, ILSAC GF-5)
Magnatec 5W30 A5 (SN & GF-4, ACEA A5/B5, Ford WSS-M2C913-D)
SynPower DX1 5W30
API SN-Plus, ILSAC GF-5, Dexos1-Gen2, Ford 946-B1
SynPower 0W20
API SN Plus, GM Dexos1-Gen2, ILSAC GF-5, Ford 947-B1, MS-6395
SynPower 5W-40
API SN/CF, ACEA A3/B4, BMW LL-01, RN 710/700, VW 502/505, MB 229.3
SynPower 0W-40
API SN/CF, ACEA A3/B4, MB 229.5, MB 229.3, VW 502.00, 505.00, PORSCHE A40, RENAULT RN 0710, RN 0700
SynPower 5w30 ENV C1
ACEA C1, Ford 934-B, JLR 03.5005
SynPower 5w30 FE
API SL/CF (High ZDDP), ACEA A5/B5, Ford 913-D, JLR 03.5003
SynPower 0w30 DT C2
ACEA C2
SynPower 5w30 MST
API SN/CF, ACEA C3, GM Dexos2, MB 229.51, BMW LL-04
SynPower 5W-40 MST
API SN/CF, ACEA C3, GM Dexos2, MB 229.51, BMW LL-04, RN 710/700, Porsche A40
SynPower XL-III 5W30
ACEA C3, MB 229.51, BMW LL-04, Porsche C30, VW 504.00/507.00 (it has no API spec)
SynPower XL-IV 0W20
ACEA C5, VW 508.00/509.00, Porsche C20 (no API spec)
Oh yeah.....SynPower 10W-50 (API SN/CF, ACEA A3/B4) for the thickies
But you get the idea
