I have owned 2 toyotas, a 94 camry and a 04 highlander, the 94 went over 100k miles in mixed driving on the (very thick) original pad and the 04 has 85k miles on the original pads now but is almost worn out.
my mechanic is a NAPA guy and uses bendix pads which he put on my maxima and the wear rate on the bendix pads looks like maybe they will wear out at 35k miles - which is not near as good as the toyota pads.
do most aftermarket pads wear out fast?in the 70s and 80s the gm originals were poor in my opinion and the replacements were even worse. 30k was good on front pads.
my mechanic is 5 miles froma toyota dealer, why wont he use their pads? napa incentives? he has bought some other oem parts like nissan coil packs after the napa coil packs set off the check engine light.
