They did say they were out of balance. Wouldnt they unflat spot in my 11 mile drive? I dont know if they checked them for out of round.
If they appear to get unbalanced after sitting parked overnight, it is likely the tires are "flat spotting".
I wish I could have got better tires from Americas Tire but they were way out of my budget. These maypops were $440 otd mounted andWith my experience with Goodyears, over numerous sets, on numerous vehicles, no weights were lost, no movement between the tire and wheel, they were initially balanced, and any 'Set' due nylon cap ply, or sitting for a bit before becoming 'round' again and running smooth was taken into account. Balance machine was calibrated, runout of the wheels was checked, the "Smartweight" feature if using a Hunter Roadforce balancer was turned off, etc.
I just think they are poorly constructed. It wouldn't surprise me to hear that other brands, especially 3rd tier brands, are too.
If you bought these at Americas Tire, they will probably swap them out for some better quality tires.
Well I don't hit curbs but I do drive on my rocky dirt road every day.What makes tires not hold balance?
Assuming they were properly balanced, the answer could be:
1) "Driving by touch"...i.e., bouncing off curbs and other road hazards
2) Poor quality off-brand tire from a Chinese or Indonesian sweat shop.
That's about it.
I did that. 2 of them have moved in relation to the rim. About 1 inch per day. Now what?I'd mark the wheel and the tire relative to each other. See if the tire is slipping on the wheel rim.
noAdding puncture sealant to your tires, mate.
I think the tires would meet to be removed and the bead and rim surface cleaned of silicone, or anything lubricious.I did that. 2 of them have moved in relation to the rim. About 1 inch per day. Now what?
@CapriRacer would know more. At least you know that's the problem
I am running lower air pressure. 25 psi as it smoothes out the wash board dirt roads I have to drive on every day. Maybe I need more air pressure? I have seen tires slip on semi trucks. Never thought it would happen on my 3600 lb jeep.I hesitated to post in this thread because I wanted the OP to provide more data.
So first, tires don't suddenly go out of balance or suddenly out of round (with a few exceptions).
Tires do go out of balance and out of round over time due to irregular wear - a misalignment condition.
So one of the things I'd be looking at in the OP's case is the road. It's not uncommon for people to forget that the problem only occurs on a certain road.
And since wheel end vibrations tend to be worst at the resonant frequency, which usually occurs in the 50 to 70 mph range, it is not uncommon for people to miss this.
And tire moving on the rim? I've only seen this when silicone was used. I've seen small slippage in some cases, but small enough not to matter.
" balanced". A comparable set from Americas tire would have been $1200
Happened to me from too much tire lube from mounting. I posted about it in a couple threads. CapriRacer gave me some info with teh possible silicone so I had shop clean everything and redo it. I couldn't find direct post but this is the long post I put on DriveAccord when it happened. One tire slipped 180 degrees, the other either 90 or 270.And tire moving on the rim? I've only seen this when silicone was used. I've seen small slippage in some cases, but small enough not to matter.
31-10.5x15... whatever load range was on sale. its not heavy and does not go fastWhat size and load range are you running?
Seems to have stopped moving..I added about 5 more psi. Dont know if thats the cureSo how far have they moved by now - at an inch a day.
My tire guy does this routinely. Always says to take it easy for a few days and if I see the lines no longer line up to let him know. They've never moved.I'd mark the wheel and the tire relative to each other. See if the tire is slipping on the wheel rim.
I found some weights in my garage parking spot after the heatwave. 115+ degrees ins't so great for stick on weights apparently.The weights fly off?
