So on the snapon chests what makes one chest better than other so chests? The slides? What’s different? I have a lot of snapon stuff but have never owned one of their chests.
KR, KRL, & KTL Boxes with the Aluminum Riser Trim were top of the line 'til the Epiq line came out a few years ago. if your going to spend SO monies....Don't bother lower line KRA boxes. KRA boxes made from the early 90's forward use thinner steel & KRA boxes before used Friction Slides
I would avoid the 70's & 80's KR boxes with Friction Slides unless the box is in VERY good shape & you don't plan on loading it heavy (per drawer)
The first Snap-on box to have BB Slides was the KR-1000, It also set the benchmark for all bigger multiple bank tool boxes even to this day. 1985 was the first time I saw them in a catalog but were produced into the 90's (Seen many '90 70th Anniversary Edition KR-1000's)
Then came the KR-1001 & KR-1003 in the early-mid 90's, The KR-1001 was based on the KR-1000 frame but added a full length drawer across the top & a Aluminum Riser to separate the 2 banks.
The KR-1003 is a KR-1001 with a Side Cab made onto it making it a Triple Bank box.
Then came the KRL "Extended Cab" boxes, A second full length albeit shallower drawer was added under the top drawer, Snap-on started advertising them as the "Master Series"
The KR-1001 became the KRL-1022 & the KR-1003 became the KRL-1023.
Snap-on went crazy with the Quad bank XXL like the KRL-1024 which is 2 KRL-1022 put together, 5 bank KRL-1053 which is basically a 1022 & 1023 frame put together in a 3 bank configuration.
Then the most ridiculous box of all time.....Two Triple bank frames put together, The KRL-1056 "Mr Big"
These boxes could rival what a decent 2 bedroom house costs in the late 90's.
The KTL series adds a 3rd full length drawer, This what I currently have (KTL-1023)
There's a low profile version of the 1000 Series boxes.....The 7000 Series. These are handy if using a Top Box as the 1000 Series with a Top Box ends up at over 6 foot tall.
KR-600 Series boxes are only 24" deep vs 29" of the KR/KRL-1000/7000 Series.
KRL-700 Series boxes are low profile versions of the KR-600 Series boxes.
I'm partial to the 1000/7000 series for the extra depth, HD Spring Loaded/Torsion Style Casters, And less chance of the box tipping over.
KR-1000's used to be a great value if you found one in good shape & didn't mind the drawer configuration. KR-1001's went for $1000-$2000 more assuming comparable condition. Each revision added resale value.
