What is the real difference between these 10w30 motor oils?
Rotella T5 syn blend 10w30 VS 10w30 passenger vehicle motor oil's conventional and synthetic blend.
I guess I'm asking can you use the Rotella T5 Syn Blend 10w30 as you would any other 10w30 oil that is supposed to be for passenger car use?
also I cannot find a spec sheet for the T5 that would allow a breakdown analysis to compare to conventionl or syn blend car oils.
