Originally Posted By: StevieC
Here's a story for you...
Before I was a BITOG member and my Santa Fe was new (after break-in) I used Mobil 1 Synthetic 5w30 and changed according to the owners manual at 6K KM (3500 Miles) not knowing any better I did this for 80K KM (50K miles). When I bought the Santa Fe I bought a ton of M1 because I had a way of getting it cheaper than retail at the time. (no longer have this connection) I literally had about 20 jugs.
I joined BITOG and learned all about used oil analysis etc. so wanting the best for my truck I did a used oil analysis. I got back the results and all the numbers were in check and quite low (including iron at 8ppm).
So.... Let me get this part clear:
You ran M1 for 80,000Km. You performed a used oil analysis on the Mobil 1. It was a "good" used oil analysis with Fe at 8ppm.
You continued to use Mobil 1 after this........
I kept using Mobil and then I read about the hoopla that apparently they had changed to GRP-III as a part of or as their main basetock for oil. Thought nothing of it at the time.
So I get to the end of my warranty with Hyundai at 100K KM (60K miles) and I see this stuff called Amsoil. So I thought I would try some. I buy the SSO stuff which is just new and put it in for a couple of changes and do a used oil analysis. I notice that the wear numbers on the used oil analysis are slightly lower but the Iron is almost in half at 4ppm. I figure this is good so I want to keep using it and seeing as I don't have Mobil left I continue on.
So, at this point, you are seeing 4ppm less Fe in a used oil analysis. Which would likely be considered noise. You could have the same sample tested twice and have this much variance.
Quote:
Then I read here about all the Iron spikes etc. and this has got me curious.
So one OCI later I dump my Amsoil and put back my trusty (good until this point) Mobil 5w30 back in. I run it for 6K KM and dump it out, then refill with more and drive to 6K KM and send in a used oil analysis. I get back the results and the Iron is at 48ppm!
So, you go from AMSOIL to M1, and get a "spike" in Fe. This could be additive clash, this could be a huge variety of things. This is backed by the fact that your earlier sampled M1 run was on par contamination-wise with the AMSOIL run.
Quote:
Scared for dear life, and before reading Doug's article I empty it out and put back in my Amsoil and drive it 6K KM and do a used oil analysis and it's back to around 4ppm again.
Very happy that I adverted disaster I check the next fill of Amsoil and again I see 4ppm.
So back to the AMSOIL............
Quote:
I then read Doug's article in the meantime and see that higher Iron PPM doesn't necessarily equate to higher wear.
I put Mobil back in for one last try and again it tests around 40ppm.
Given the exact same scenario that precipitated your previous "spike" I don't find this surprising at all.
Quote:
While I didn't notice any performance change or metal filings in my oil pan, on the drain plug or in my EAO filter with FilterMag there is definitely something spiking these numbers in my engine when it comes to Iron and I just can't sleep at night IMO, taking a chance that I could be risking the engine with these numbers.
But there wasn't. For 100,000Km there wasn't. It wasn't until you started changing around oil brands to "see the difference" that the numbers changed.
Quote:
So I switched back to Amsoil and stuck with it. Since then I have tried Pennzoil Platinum and some Dino's that peaked my interest and none of them that I had a used oil analysis done on showed the Iron levels that M1 did.
But again, it didn't in the beginning. Trying it ONCE after an AMSOIL run, and then condemning it..... Yet for 100,000Km it was fine, and the used oil analysis "wear numbers" were on-par with you AMSOIL numbers during this period....
Quote:
I'm not saying that this in anyway equates to M1 causing wear, but I sure as heck am not going to see in time what happens.
100,000Km was a lot of time............
Quote:
If Amsoil isn't that much more than M1 and doesn't report those same elevated numbers to me it seems like a logical choice.
Cheap insurance I guess...
But again, at the beginning this was not the case. It was not until you started swapping out oil brands that you started seeing the spike. This to me should present itself as a red flag as to being an issue with the METHOD being used here.....
You run M1 for 100,000Km. It gives you "great numbers".
You run AMSOIL for an OCI. It gives you "great numbers".
You run M1 for an OCI. It gives you "freaky numbers".
As Doug has posted on in detail, used oil analysis are a TRENDING TOOL (and shouldn't be used to gauge wear, but anyways). You cannot form a conclusion based on the above methodology. You would have had to run the M1 for numerous consecutive runs to see if the Fe dropped back down to its original sampled M1 levels.... PRE-AMSOIL, or not.
But you didn't.
Instead, you instantly became alarmed by the numbers the used oil analysis gave you, fed by the fears and fear mongering of this topic on the board, and switched it back out for AMSOIL.
The reason tig1's numbers are "normal" is likely due to the same reason your original set of numbers was "normal" until you started switching around the oil you were using. He's run ONE OIL for the duration of his car's existence. And observed the same thing you observed for your first 100,000Km.
