Do you know why the power goes up? More oil means more lubricity of the mix both above and below the piston. This equates to less friction. Same effect can be had by a higher quality oil without having to resort to lower mix rations like 32:1, 20:1... An oil which supplies the same lubricity but at a higher mix ratio will make more power as the volume of fuel and air combusted will be greater.
How much power do you think you could make at a 1:1 ratio?
As far as price goes. interceptor is HIGHLY over priced at $28+ per gallon. Mx2t is around22 per gallon, phillips injex pro is around 15 per gallon, and citgo sea n snow is around 12 a gallon. [/QB]
As a commercial entity your price would be considerably lower than the Mx2t.
You almost answered all my questions.
1. What was wrong with the intruder oil in your opinion for the application you used it in?
2. What ratio did you run the oil at or was it just run through a stock injection system?
