- Joined
- Nov 29, 2021
- Messages
- 5,387
Thanks.
You've just nailed my confusion with the whole thing. I read a number of articles, for what can be considered articles nowadays, and they described it as you do in your second paragraph. Or others equally nonsensical.
It ain't easy to sort out. But, if I'm reading your description right, a 0W-40 will not flow thicker then a 40 in the cold? While a 5W-30 will flow thicker then a 30 in the cold. Does that make sense?
Hey, thanks, no problem, and I thank you. I had an interaction with a YouTuber that infuriated me, pretty much on the basis of incorrect oil information. The rest is history. I've dedicated my life to the truth. So let's continue with what you're learning, before I have to break away for a bit.
The short answer is that the way you summized it is not correct. Let me focus, and explain.
You summized:
While I see where you are thinking, the short answer to that is, no, that is not it.
Fundamental to understand, and what will set you apart in your superior oil knowledge to others, is that it is always a 40 in that example. The first number has nothing to do with the second.
If you are talking about a monograde 40, then that is correct. A monograde oil has no W or Winter rating.
People that think it does are, bluntly, not correct. This is the source of much misinformation.
The first number is separate from the second.
While a 5W-30 will flow thicker then a 30 in the cold?
This is the most confusing part of all. Some 5W will flow better than 0W.
I now yield the floor.
