What is my Honda Pilot engine's REAL problem?
NH
I have a 2009 Honda Pilot I bought new and have maintained as per dealer recommendations, which is to use the on-board maintenance minder computer. At 80K miles the engine developed a tick in the valve train, which has since become louder. At almost 90K miles the dealer went to do a valve adjustment but instead told me that the engine has heavy sludge which caused premature wear of the camshafts, probably cylinder heads, and possibly lower end. They now recommend significant engine work, engine replacement, or vehicle replacement. I am troubled by the fact that my dealer insisted the Pilot would be fine running conventional oil as long as the 9K to 10K mile service intervals the maintenance minder ran before indicating an oil change was due. I spoke with Mobil who told me that the conventional Mobil Super oil the dealer was running had a 5000 mile rating and although this oil would continue to lubricate beyond its rating, the additives and detergents would begin to break down after that point. My conclusion is that the maintenance minder on this vehicle was operating in error by letting conventional oil run as long as it did, and the breakdown of the overused oil caused the accumulation of sludge over the lifetime of the engine. This seems obvious to me as I have always changed my oil at 5000 miles, yet the dealer service department said they, "Just don't know" what happened. My dealer's parts department told me that Honda started using synthetic-hybrid oils for their 2011 models. Can someone please tell me if my conclusion is correct, or if there is another solid reason for what might have happened here? Many Thanks!
The only thing I can add to this discussion is that I've read on here that some Honda Minivans equipped with the 3.5L V-6, that were maintained in a similar way, developed problems with heavy varnishing that affected camshaft opeartion.
The Pilot uses the same AFAIK, so i'd expect this to be a similar issue. MOST Honda engines are very easy on oil; it sems like the 3.5L is an exception to that rule.
I have never believed dino should be used for much over 5K. Now I know there are some exceptions. Both of my engines have nearly 100K all on M1 synthetic with 10K OCIs and they are very clean. I also would not put any trust in a OLM as often they will have the OC well in excess of the life of dino. Of course this is my opinion and will stick to it.
I'd get a second opinion. I think member Trav dealt with a sludged up Honda Odyssey which was also maintained by the MM. IMO I'd can the MM and do shorter OCI's maybe 5000 miles with a synthetic oil, if in fact your engine is as bad as they say it is.
Your case is NOT an isolated incident. There are many reports of this same problem on other Honda-specific forums - we might've even had another poster asking something similar to this a few weeks ago, I think.
Whatever it is, it's a shame. I'd lean towards undersized sump (4.5 qts) and the OLM telling you to go much, much too far.
Is this a 3.5? I would be nervous even running synthetics without a UOA to insure at least the TBN was holding up.
If this is an iVTEC i wouldn't go over 5000 miles.
You are the victim of a bad service manager.
The engine sounds like a dead player replace it with a long block.
Open up a claim with Honda directly and see what they will do. There is a good chance they they will help you out especially if your vehicle was dealer serviced.
That's terrible to hear. Did you have all the oil changes performed at the Honda dealer? What engine is in your Pilot: the normal 3.5 V6 or the i-VTEC with the Variable Cylinder Management? Did you do a lot of towing or other severe service? I am very interested to hear more as I also have a Honda with the 3.5 liter engine.
Again, sorry to hear about your troubles and I hope things work out for you. I think the Maintenance Minder is way too optimistic for this vehicle, especially with conventional oil. That is the most likely reason for the sludge. The dealer and Honda should stand by their recommendations.
If the oil was changed every 9 to 10k miles with a decent quality conventional oil such as Mobil I highly doubt it would sludge up severely to the point of engine failure...Did you actually see sludge with your own eyes? Can you see any sludge through the oil fill hole? At 9-10k OCI I'd expect maybe varnish but not sludge.
Either the motor burned excessive oil and it ran repeatedly low, the dealership failed to change the oil on one occasion, they used cheap swill motor oil and passed it off as Mobil or they are claiming sludge to pass the blame on you.
Out of curiosity, did you do a lot of short trip driving with this vehicle?
Originally Posted By: Hallmark
With 9-10K OCIs on conventional oil in NH climate, there should be no question as to what caused the sludge issue.
Yeah the engine.
nice first post welcome to bitog and i hope you arent a trolling
formerly banned member here.
Sorry to hear about this; painful no matter if Honda helps or not. I recently switched to Mobil Super from Pennzoil Ultra and although we do not have the same engines/climates/driving styles, I will be incrementally moving up from 5K and performing UOAs to see how MS5K holds up past 7.5K.
The TBN in my engine at 5,142 miles was 3.7 and it starts at 8.4. If your engine is particularly hard on oil (and it sounds like your model is), I will opine the TBN was exhausted somewhere past 8K and when combined with your climate and perhaps short trips, sludge developed fairly consistently in the engine.
Crazy, I follow the OLM on my Civic and so far the oil fill hole shows a completely spotless top end. Nothing in there but clean metal. About 61,000KM.
This is one of the reasons I run Amsoil. Expensive oil is really cheap when it prevents these problems. I run the oil out a way to get my monies worth. Lots of people like using conventional oil, but I would not feel comfortable running it past 3K without a UOA.
Probably a good wake up call for others using OLM to tell them when to change oil. Doing a UOA every once in awhile is a lot cheaper than dealing with your situation.
I would try to get Honda to meet you part way on the deal as a goodwill gesture on their part.
Conventional oil doesn't go 9,000 miles. Sorry.
Car ownership requires some basic knowledge - like tire pressure, what oil to use, ect. You should have checked the owners' manual for the correct oil if you were not sure. Otherwise, you should have changed at a reasonable interval.
This is another example that the blame is going to on the oil not the poor design of the engine.
