Originally posted by Pablo:
WL - Must have been a good dinner... Or are you still typing?
ah ah aaaahhhhhhh....oh sorry....we now return you to standby and wait for the regularly programmed post: "What is Gravity?"
Just building the suspense.
Actually I got tired and went to bed after dinner.
I actually use to do a lot of thinking about gravity while drinking beers in the bars around Princeton NJ and N. Brunswick. I use to commute weekly from here to there. So grab a beer and follow along.
I came to the conclusion that the effects of gravity were no more than the fluid pressure differences between what we call matter and all things currently observable.
Imagine if you will a giant fish tank filled with water (the ether in the vacuum of space and between particles.) Now this tank is sealed on all sides and is under pressure. To keep things simple we will introduce a foreign substance (air, oil, whatever) to represent matter. The substance will be introduced into 2 places in the tank. Now the pressure around each bubble of air is not uniform because of the disruption cause by the other bubble. Now the pressure between the bubbles being less than the pressure exerted on the other sides causes them to be pushed towards each other. This pushing is GRAVITY. The closer two objects are, the greater the effects are felt as the angle of disruption is greater. Also, the more mass an object has the more it effects the pressure between two objects. This is because more of the push is absorbed by the greater mass. Think of the push from the sides of the universe being blocked or absorbed by an object standing between you and the ends of the universe. A denser objects absorbs more of the push.
There are limits to the elasticity of the ether. This is what limits the velocity of objects traveling through it. This limit of linear travel is defined as somewhere near the speed of light in a vacuum.
Now this ether which behaves as a liquid can be manipulated in the same way. If you swirl it as though you are rapidly stirring it then a cavitation vortex is created in which no ether exist. This vortex can be used to overcome the effects of gravity and acceleration. An object traveling through this vortice experiences no acceleration forces nor is it limited to the velocity of light.
Now is there any examples which might support what I suppose?
1. A black hole is supposed to have a gravitational force so greate that nothing can escape it. Yet, spinning black holes are known to eject material out of a top and bottom as though there is no effects of gravity at these two spots.
2. Recent experiments have shown that a rapidly spinning superconductive disk negates the effects of gravity both above and below it by a small percentage.
3. In the wave-particle duality problem in quantum mechanics a photon is shown to exhibit both qualities of a particle and a wave. A single photon is fired through one of two slits in a wall and strikes a photographic plate in the room on the other side of the wall. This is done first with one of the slits covered. Repeating the experiment causes the photon to strike the same spot over and over. Now remove the cover of the other slit and again fire into the first slit. The photon now strikes a different spot on the photographic plate or is cancelled out and does not strike anywhere. It now behaves as though it were a wave going through a jetty that collides with another wave and cancelled itself out. See The Dancing Wu Li Masters pg 58-66. Supposedly this is one of the thorniest problems in quantum mechanics but I think it is as easy to solve. The photon is generated at the light source (from where? still working on this) and travels riding along a wave in the ether at the speed of light (ether waves) along a known vector. This wave passes through the two slits and it bends at the two slits instead of just the single slit. These two waves converge and the path of the photon is changed. If the photon arrives at the trough of the two waves its movement ends. Now, does it cease to exist or does it still exist waiting for someone or something to collide into it?
This would suggest the existance of a medium like the ether which explains the wavelike behaviour of the photon. It would also show that the ether (fabric of space) can be manipulated.
4. A working antigravity device.
It's getting late and I am having trouble concentrating. I think I will pick up later with number 4 and one of my experiment called "Bubbles in space" which is used to test a theory on the constancy of gravity and how to determine the shape and our relative position in the universe. I have more but I must go and get some sleep.
Until later. Ponder on dudes.
Mike
