What is a good substitute for Mobil DTE-15?
Hello. I have a question on what I should use. I bought a older platform lift that requires Mobil DTE-15. I can not find this available. Would Mobil DTE-15M be good to use? Or would a AW46 weight work? A little confused on what I can substitute here. Many thanks for your time here. Regards Bob T.
It's called DTE 10 Excel 46 now.
Rando HDZ 46 would be a good cross, though if it's used outside I'd run 15 or 32, at least around here.
Hello Sumboodie. Thank you for clarifying. Many thanks for your time here. All the best. Bob T.
most any brand # aw-46 hydraulic oil can work,there is nothing special about Mobil oil, check your hyd. filters also.
