Finally got around to changing the brake fluid in my 2008 Sonata. I asked about the bleeding order some time ago and that's the sequence I followed. I used my Mityvac 7201 with the 7205 brake bleeding kit.
The problem: My brake pedal, which was perfectly fine before I, uh... worked on the car, now travels about a mile and a half before resistance is felt. The brakes "work" but obviously this is not proper.
The procedure I followed:
I wanted to evacuate the master cylinder, but Hyundai has a screen under the MC cap, and I didn't want to deal with prying it off, so I left the old fluid in there, and started by topping off with Valvoline Dot 3 & 4 fluid.
Per Hyundai's specs, I started at the right rear. Made sure the area around the bleeding screw was clean, put the 7205 nozzle on there, started suction, loosened bleeder screw. I made sure that suction on the 7201/7205 was never lost. And I tightened the bleeder before removing the 7205 nozzle.
The right rear is the one that took a relatively long time, because of course all the old fluid had to be removed from the MC and pulled through the lines. I evacuated brake fluid a few minutes past the point where the fluid looked new.
Every 30 seconds or so I topped off the MC with new fluid.
Then did that procedure with the left front, left rear, and finally the right front.
I expected a full stream of brake fluid, but what happened at each wheel was that it dribbled into the 7205's hose. I didn't think that was a problem as long as suction was maintained.
I don't think the MC got too low at any point. There was no point at which I refilled it and it wasn't already close to being full to the brim.
I'm curious on what went wrong and even more curious on how to make it right. Obviously doing the same (wrong) thing a second time won't help.
Please, BITOG gurus, advice.
