What grit is considered Emery Cloth ?
Joplin
I am going to do a timing belt job and replace all the engine oil seals. I often read of taking some emery cloth to polish the shaft just a bit before installing the new seal. However, I never learned what grit would be considered "emery cloth". I have various fine grits of wet + dry sandpaper so would like to know what might be a good grit to use to polish the shaft ends before installing the new seals?
I know one does not want to introduce new scratches; just to polish the metal to remove anything left by the old hardened seal and smooth up the shaft end as needed.
I guess this same question would apply if one was to replace the connector rod bearings, some use emery cloth to polish the crankshaft surface before installing the new bearing but I never read about the grit level.
Emery is for metal. I have used the 3M emery fine on Spyderco knives the last couple purchases because they are not finishing the thumb opening hole. The fine leaves a smooth surface.
The coarse grit emory cloth is comparable to 80 grit sandpaper. I just found that out yesterday while at the hardware store. I don't have the comparison numbers for the medium and fine grit yet, but I will on my next trip to the store. The emory cloth that I was comparing is the 3M 011K series.
No thank you. Emery dust and assembled engines don't mix. I just leave the seal out a bit or in a bit so the lip doesn't contact the worn area on the shaft.
