Why?quote:
Originally posted by MC5W20:
Using a 10w30 would give him less oil pressure in a motor spec'd for 5w20 oil.
Why?quote:
quote:
Originally posted by jbas:
Geez, well if its 5W-20, then no one better use 0W-20 or *** forbid, 0W-30, synthetics. Not spec'd.
How about this? Let's let Ford continue to antagonize its dwindling customer base further, and they can go away altogether. What are they now? 16 - 18% of the market? and falling...
Good, let them go belly-up.
quote:
the relative growth of fleet sales isn't the important part. Rather, Detroit's conventional retail sales to individuals have shrunk, leaving fleet sales as a bigger proportion of Ford's total than in the past. On average, fleet sales have been running at about 25 percent of total sales; in January they surged closer to 40 percent for Ford and GM.
Maybe you should start a separate thread for that Goldenrod. There is some disagreement to this. Best way I can answer it is get a set of gauges and hook them up to a motor designed for 5w20 and measure the pressure after the oil pump. Use different weight oil, take the car for a drive and observe oil pressure over the driving cycle.quote:
Originally posted by GoldenRod:
Why?quote:
Yes. The volume pumped is inversely related to the viscosity. Same thing for the flow through the bearings. The rise in temperature of the oil in the bearing is directly related to the viscosity.quote:
Originally posted by Ray H:
Doesn't the oil pump's pressure relief valve determine the working oil pressure? If that's correct, then wouldn't it follow that oil pressure is constant (at least within the tolerance of the oil pressure relief valve's mechanics) with the real variable being the volume pumped, right?
You obviously never owned a BMW/MB/Audi. For whatever reasons, they just can't survive on low viscosity oils.quote:
Originally posted by ColdCranker:
Look at BMW specifying high viscosities in new cars. They do that because BMWs are typically driven hard, certainly in Europe, and also in the U.S. More viscosity helps hold the oil film together under pressure.
Mobil 1 5w20 meets the A1/B1 specsquote:
I see your viewpoint, that 20 is not a bad number, but do you see an Xw-20 that passes the grueling ACEA A1/B1 A5/B5 tests?
Wrong again. My '01 BMW 525iAT looked good next to my '40 and '41 Chevy until I sold it recently. The viscosity BMW specified was high. Why was that, do you think?quote:
High viscosity? BMW's specified oil in the US has been their LongLife 5w30 for years (which is nothing more than relabeled Castrol Softec TXT 5w30).quote:
Yes, they have to demonstrate a certain percentage better fuel efficiency than a 5w30 3.0 HTHS standard oil. HTHS and fuel efficiency correlate fairly well.quote:
" ...Sequence VIB requirements "
Is that due to less fuel economy with the higher HTHS?
Just speculation, of course, but perhaps the engineer was there precisely to help Ford make that case. They know that they have the burden of proof if the case goes to court, and they also know that they'll need an engineering expert to meet that burden. There won't be any engineers poking around when you've got a broken radio face plate, but an engine is, obviously, a rather expensive thing to replace.quote:
Even if the engine was designed from the drawing board to run on 5w20 I can't believe 10w30 would cause a spun bearing. I think Ford would have a hard time making that case.
On the other hand, I would think the PCM memory may record the number of times the engine was taken past the redline, in which case driver fault would be easy to prove.
