What fluid does a DIFFERENTIAL on a Auto Vibe use?
northeast
What fluid does a DIFFERENTIAL on a Auto Vibe use? And where is it located? I know my Chevy prizm with the 1.8 L Diff is seperate from the transmission.
The differential for the front is serviced with the transmission, as one unit. Unless you have an AWD that has a servicable transfer case and rear differential.
I think they are together now. Not hard to tell by looking at it from under neath. My Camry only has the one drain plug and the diff is in the trans and shares a common fluid. Mine is a 5 speed manual though. So if it is an automatic some Dex IV should do nicely if it is a manual then get some MTL and MT90 from Redline and mix 50/50.
I think the Pontiac vibe was built with T-IV fluid.
