It's a 70's era Briggs. The recoil mechanism confirms..My old Lawn edger doesn't have spark. i'm trying to find out what brand it is, so that I can order a coil, if that's what it needs. Here are some pics.
Oh ok. I didn't know it had a point. Thanks!It's a 70's era Briggs. The recoil mechanism confirms..
Don't order a coil ( I doubt that's your problem) until you pop the flywheel off to lightly clean the points with an emory cloth. Then pass a dollar bill or a piece of paper between the contacts to clean. I would bet that will solve your problem. Verify the point gap is at .020 and If the flywheel key is damaged, replace it before installing the flywheel.
A damaged flywheel key itself will never kill the spark , as long as the crankshaft is able to turn with the flywheel which it would probably do even with a sheared key.. A sheared key will affect the timing of the spark and create a no start condition.Take a close look at the aluminum flywheel key after you get the flywheel off. The engine will lose spark if it is even slightly sheared.
Negative. A B&S engine with points will lose spark if the flywheel key is sheared (in some cases, even partially sheared). The electronic Magnetron ignition will not lose spark.A damaged flywheel key itself will never kill the spark , as long as the crankshaft is able to turn with the flywheel which it would probably do even with a sheared key.. A sheared key will affect the timing of the spark and create a no start condition.
Might check the condenser too. I've found a few bad ones over the years, but not often.Oh ok. I didn't know it had a point. Thanks!
The condenser on this engine has one of the two points built on top of the condenser, so the points and condenser only come as a kit, part number 294928.Might check the condenser too. I've found a few bad ones over the years, but not often.
Sorry not drinking the kool aid. Explain how that could be. I had sheared keys on old Briggs engines and had a spark.Negative. A B&S engine with points will lose spark if the flywheel key is sheared (in some cases, even partially sheared). The electronic Magnetron ignition will not lose spark.
Back in the day, when these small engines were first designed, B&S specifically designed the ignition system to lose spark if something was hit hard enough to shear the flywheel key so that an average homeowner would have to take their mower to the shop to get it fixed. They did this for safety. They wanted a professional to look at the mower to determine if it was damaged in such a way as to be dangerous.Sorry not drinking the kool aid. Explain how that could be. I had sheared keys on old Briggs engines and had a spark.
I'll check later today. If it's points, would this work to make it electronic? https://www.amazon.com/Raogoodcx-Re...prefix=electronic+coil+briggs,aps,269&sr=8-20I still can't see from any of your pictures whether or not there is a wire leading under the flywheel. If there is not, it would be electronic ignition not points.
Doesn't look like that would work, it says it's for 10-13 HP L-head, and others have said you probably have a 3 HP or smaller. I'm thinking that one is designed for a larger flywheel, so even if the mounting holes are the same, you won't be able to set the air gap correctly because the curvature won't match. Is there a wire from the coil going under the flywheel? If not, maybe it was already converted at some point. A better picture of the coil (specifically, the armature side that faces the flywheel) would help. An electronic ignition would have a small round pickup next to the large coil that has the spark wire coming out of it.I'll check later today. If it's points, would this work to make it electronic? https://www.amazon.com/Raogoodcx-Replaces-Stratton-Electronic-Ignition/dp/B01IOOKOOK/ref=sr_1_20?crid=3F6LDP6WKGH8F&keywords=electronic+coil+briggs&qid=1649789514&sprefix=electronic+coil+briggs,aps,269&sr=8-20
So i look for Briggs 5hp electronic coil?Electronic coil upgrades were available.
