Quality is a plastic, that is well preserved so it doesn't get all brittle.
True, it hasn't been a problem with any car I've had since '93 TBH. But I have seen a fair share of plastics before that which suffered the 'weathered lawn chair' look.
Originally Posted By: Spazdog
Originally Posted By: ItsuMitsubishi
... This definitely includes thoughtful engineers that greatly consider ease of servicing, and not just the ease of assembly! *cough*GM*cough*
Well, that pretty much eliminates most German cars from the definition of "quality"
They might as well have a "
NO USER SERVICEABLE PARTS INSIDE" tag on the hood release.
Mercedes Benz doesn't even let you check your own transmission fluid level. There is just a cap that says "MB WORKSHOP ONLY" on the transmission dipstick tube.
Oh nein, you are too ztupid to check ze fluid. "
Then there's the indecipherable pictograms on the controls. What does this one mean? Is that a Weber grill and a lightning bolt? Well I definitely don't want to push that button!
So they move everything to a screen in the center of the dash and give you a mouse-like control. Good idea except they think very little about navigating their interface and user friendliness. It's not very intuitive and generally a pain in the neck to use. ( neck is not the exact word I wanted to use but it will suffice instead of a
[censored] .)
Then if you do decide to dive in you will find that they used 3 or 4 different sizes and styles of fasteners on one assembly. Completely unnecessary. For a nation that prides itself on efficiency in manufacturing it's a remarkably inefficient practice.
I thoroughly enjoyed reading that. It's not just contemporary German engineering afflicted with such irritants. Hate to do it, but back to GM- I did a coil pack on a Buick 3800. Wanna know what size bolt used is on them? Five-and-a-half millimeter. Not 6, not 5, 5.5. I was like "are you ****in' kidding me?!?" The 5.5mm must have been the last socket I tried and lucky I had it. *note: while I'm sure there was an imperial equivalent to the 5.5mm, there is no good reason for it to be that size period (or for the coils to fail so often). I'm a metric guy, and most other cars need the basics: 8mm, 10mm, 12mm, 14mm, 17mm, 19mm, 21mm and usually nothing else.
That MB transmission issue bothered me too. It's not like you can buy the dipstick and leave it in there either, it's a 'measuring tool' only. And it's only graded in mm, ie theres no F or E marks. It must be corresponded with fluid temperature which must be electronically read from the bus. What the wooden-hoot? And you cannot use a flat flexible steel rod either, the contortions make that impossible. It must be coiled to make several angles. I just used a piece of mower throttle cable, scored it to match the original cold fluid level and called it a day.
Originally Posted By: d00df00d
Besides, a lot of this stems from customer expectations and ignorance.
If we as a general public didn't demand useless junk, we wouldn't need kidney-shaped batteries and ridiculously complicated electronics.
for some reason I can't stop laughing at the "kidney-shaped battery". Of all the needless things to do! Of all the shapes to choose!
That whole iDrive/maint interface is ridiculous. I was driving my uncle's 330xi and was running through the menus, looking for oil level and drain interval. I don't know if i accidentally hit some reset button, but everything just said even KM numbers for full intervals like "10,000KM" oil , "25,000KM" brakes (or something to that effect). I know he didn't just have the car serviced. Either I screwed something up with a stray click, or the information offered were just useless values nromally found in the manual.
That nonsense is really just too much. I don't want to have to accept some EULA/disclaimer every time I drive my car either. Ironically, if you drive off before accepting, having to fumble around and click accept just to change radio stations is a hazard and distraction in and of itself. It begs only one question: WHY?! But I digress...
