All of these products like Ceratec and Archoil 9300 may be an overkill but they can be fun to play with. Archoil states to use their cleaner (AR2300??) for 3K miles before using AR 9300 unless you have been running AR9100 which does not offer ceramic coating but is slicker than AR9300. In light of that I am thinking about gallon of Archoil AR9100 and run it in everything since it is for engines, transmissions and hydraulic oil. In manual, auto transmissions the mixing ratio goes to 10% making it go fast. My try some in the old backhoe but it would cost $400 to fully treat it. I can do it with Lucas Hydraulic Oil Booster and Stop Leak for only $60 but they are not designed to do the same thing.
For engines at we change (none hold more than 2 gallons) we just go with synthetic engine oil how ever at the quick lube places I just go with house brand conventional to offset their labor charges. I like Shell T6 as the oil to stash because it is good for the lawnmower to diesel engines but after some testing really like Mobil 1 10w-40 High Mileage oil for the gas engines as all are 100K to 200K+ miles. It is the slickest oil out of the bottle that I have seen and sticky too. I used it as the rebuild oil in the Polaris engines and was impressed. It may be the moly but it seems to be good cutting oil and adds to bit life.
On the 2000 150K towncar with Ceratec with over 3500 miles on it we will monitor. Checked today and on local driving it is showing 19.3 MPG today after the 3500 mile trip last week but did not really test it right before adding Ceratec but that is higher then in the pass. It may have been winter but once after many tanks it was more like 11 MPG but if it was idled a lot at start up that would have been a factor.
Other than the engine being more quiet we see no major pro or con at this point with Ceratec.
