What do you drain your oil into?
an open top drain pan, then into whatever proper plastic jugs I have around... usually either an oil or fuel additive jug, a milk jug or a detergent jug...
JMH
Originally Posted By: GROUCHO MARX
Originally Posted By: ls1mike
I use all my old kitty litter containers...My buddy then burns the stuff in his waste oil furnace.
Now that's green!
My lawn was full...
I had to do something...Look at the stuff I drive!
Originally Posted By: Al
The problem is that it is not deep enough and the oil splashes out of it. I hate it.
I use that exact same drain pan, but then I transfer it into the large kitty litter jugs for transportation to the recycling site I go to. I know what you mean about the splashing though, I was trying to do an oil change today and the oil took forever to drain into the pan, it just kept bubbling back up, I realized I forgot to open the tiny little air outlet, but even when I opened it, it didn't seem to drain any faster. The first time I used it though, completely empty, it worked perfectly. I don't trust it for transportation. The last one I had (also made by Blitz, 10-quart with yellow cap) liked to leak because the big cap on top wouldn't tighten properly.
i use 2x 3L milk bottles after draining it all into a 10L pan.
yet to figure out where to take the waste oil down here, not many places seem to want it.
Makes a great target...
That is what happened to mine.
Piece of junk.
With all the sure drains on the engine that I change I just drain directly into a 12 qt jug that I bought from Wal-Mart.
With the Fumoto, I have to drain into a 6 qt pan THEN drain into the jug.
Everything goes to a recycle bin.
Bill
I drain into a 6 qrt. pan for which I transfer to a 25 gallon container with a drain spout. I have four 5 gallon paint buckets with lids that I use to transport to the Advance Auto Parts store when my large container is nearly full.
About four years ago, I was using one of the black 10- or 12-quart drainpans with the big yellow lid on top and a yellow cap on the pouring spout. Then the pan, without warning, began to leak during a change. Not a dribble, either, but a steady stream from that little spout cap. Thanks the ghods it began to do that before I put it my trunk for the trip to recycling!
I disposed of that piece of garbage, never mind how, and bought a Topsider. I would draw the oil out of the dipstick (my Benzes were designed for that), and its 8-quart metal can held the oil from my changes. Seal it up and take it to Autozone; done.
The Buick isn't designed for oil extraction, so now I have my changes done by my regular mechanic. When or if I buy ramps/jackstands and do it myself, I'll use a cheap 6-quart pan, then drain it into the Topsider can for recycling.
I use a 12 quart bucket and then empty that into 5qt jugs. I have one of those blitz containers, but they really are not very good to transport.
