Since we bought my wife's '01 Olds Intrigue new, I've done 3 ATF drain (syphon actually!) & fills with RL D4 and I was all proud of myself for having switched out most of the OE ATF with synthetic.
Well recently, on rare occasion, the trans would do some firm upshifts instead of the "smooth-as-butta" shifts we're accustomed to and I started to wonder if using D4 was a good move.
This weekend, I dropped the trans pan (replacing it with an MSP pan with cooling tubes and a drain plug), replaced the filter and refilled the trans (~7.4 qts to be exact) with Mobil 1 ATF. So far so good but I'll see if this fixes the occasional hard shift problem. I hope it's not a more serious mechanical or electronic problem.
Those with 4T65E transmissions, what ATF are you using and how's your transmission running with it?
Thanks!!
Thanks!!
