You're probably a BITOG'er if you intuitively know which kind of oil your engine "likes." Bonus points if you can hear the difference.
A lot of BITOG'ers WISH they were still middle aged, LOL.Middle age men.
Correction... middle age and above men.A lot of BITOG'ers WISH they were still middle aged, LOL.
That’s me . I found watching other people’s doing oil change or transmission or rear diff relax me. On the car I own or the cars I like to own .If you have watched a video of a oil change on a car your considering buying just to make sure it's a user friendly car to service and take this into consideration on the purchase decision.
Bonus points if you have then done research on what filter and oil you would use before even buying the car.
I recently learned my GX has a "thermal degradation of transmission fluid" algorithm." So even Toyota doesn't claim it's a lifetime fluid all the time! (this factor accelerates when certain ATF temperature thresholds are exceeded).Knows Toyota is out of their minds if they really think WS is "lifetime" fluid. Blasphemy!
Guilty……..only it’s a 25 year old beater! And 90% of the parts are NLA!Buy a 10 year old beater with unknown maintenance, worn out suspension, barely passing emissions, but all you’re interested in is “what’s the best oil for it”.
I own none of those thingsTo be a true BITOGER you must have at least TWO of the following.
Cutting open a filter that's been on your engine for 3000-10,000 miles is kinda too late in case you find an issue, no ? And just because someone finds an issue with filter "X" doesn't mean that every single one produced also has that same issue. Then you have people who buy (2) filters, cut one open and if it's good, they use the 2nd one. They seem to think that "the one was good, the other one must be too".I refuse to buy a filter cutter.
I respect the guerilla street mechanic who gets things done. BITOG would lay a tarp down on the tile garage floor, change the oil, launder the tarp, then press and starch it for next time.You change your oil in Walmart parking lot because not allowed to at condo or apartment complex.
Consider it done.Does an oil extractor and a 27mm oil filter cap socket get me in?
So dangerous for the experienced crowd. Never leave a dry sump.Have we missed letting an engine drip drain overnight ?
Process control. There’s no reason to let it drip overnight when a proper (hot) drain will have it dripped out in minutes.So dangerous for the experienced crowd. Never leave a dry sump.
