What connector is this?
Trying to replace this 12V lead and I want to use a new connector for the relay. I know I can use about any female connector but trying to keep it looking the same. I figured this was an easy to find item but proving difficult for me. Just one of many I need to fix on this vehicle.
Maybe someone knows off hand.
It looks like the standard issue 1/4" female spade connector with a common sheath. Because this setup is not weather proof, dust proof, nuclear, biological or chemical resistant you can replace it with a simple WalMart sourced crimp terminal if you so choose.
You can get it nekid-
with a fancy heat shrink sleeve-
or even with the plastic housing to make it look factory fresh-
No link. They're so common that you can do a search and find anything you want.
What vehicle are you working on? This can narrow down where to search.
What gauge wire is that (approx)?
That relay is an aftermarket alarm on a Jeep, been about 15 years since install iirc. I will double check but I believe 12 ga.
