Originally Posted By: LeakySeals
Originally Posted By: tig1
Originally Posted By: BlueOvalFitter
Originally Posted By: Donald
One thing mentioned on CarTalk is that compression can be fine when the top 2 rings are working as designed, but the 3rd ring is worn or more likely stuck/crudded up.
Not trying to hi-jack the thread but this is a very interesting subject. Can some members chime in as to the best oil to use to to prevent this or cure this problem?
A quality synthetic will prevent this. In all my years of using Mobil 1 oils at 10K OCIs I have never had an engine use more oil at the end of my ownership than at the begining. Synthetics are more resistant to coking and sludge than dino.
From new it will/might prevent. Try it with a used car and see what happens. I'm 0 for 6. Fools gold to think syn will magically make oil burning go away. Once a burner, stay with dino, a High Mileage oil, or get it repaired.
Read more carefully. I for one did not say that synt. will remove cokeing from rings, although it may help over a long period of time. I said synt. oil will prevent coking.
