car : 97 Tbird 4.6L with 113k miles.
symptoms: rough, shaking idle when in D (and park, but more in D), engine sounds like weakly "revving" by itself at idle, and sounds like a diesel, especially after warmed up.
seems 95% fine when when driven, almost like normal, but I did feel less power than usual.
idles almost like normal when engine is cold.
Gas mileage has gone down a lot suddenly!
no check engine light.
plugs/wires are only about 25k old.
oil level fine. fuel filter replaced recently, and a/filter, too.
can't be bad gas, 'cause got some new gas when almost empty, and still did the rough idle thing.
o2 sensors are still oem.
no weird smells, etc.
recent codes:
within the last 2 years (twice): "bank 1 catalyst: efficiency below threshold"
(never did anything about it, 1st time had code erased, 2nd time went away by itself...the 2nd time was about 7-8 months ago, I think;
on both times when the CEL came on, car drove perfectly normal, that's why I never did anything about the code)....could this be it?
what do you guys think this could be...?
Thanks a lot.
[ August 08, 2006, 06:29 PM: Message edited by: 97tbird ]
recent codes:
Thanks a lot.
