What are you working on today?
I have this cheap Carry On trailer from Tractor Supply. The license plate bracket that comes with it that hangs off the light is hilariously flimsy. Pretty sure if I hit some rough road it's gonna snap off.
Bought some 3/16 flat stock to make a holder. I'm used to using a 480V welder at work, so this 120V one I have here took a minute to figure out :ROFLMAO:
Painted
Mounted
Painted
Mounted
Are you going to mount a light so you can use it after dark?
Painted
Mounted
Crocodile Dundee voice:
"That's not a knife license plate mount -- this is a knife license plate mount."
Seriously, though nice work
You know what, I never thought about that. I'm totally getting pulled over now :ROFLMAO:
Not planning on using it after dark though.
Around here most trailers don't even have plates. If they have a plate the tags are long expired. A cop would have to have a personal agenda or a really bad day to nitpick a light.....but, sure, technically it's a violation.
That first sentence :ROFLMAO:
The industrial technician in me couldn't leave well enough alone. I bought some tie downs to weld on, but I need to load the mower up to get the positions where I want it.
Allegedly they pay the welders $8 an hour to weld those trailers together (parolee and day laborers). Pretty sure I'll have to get the welder out again. It just hauls my mower and lumber occasionally, not like it gets used everyday.
  • Wow
Reactions: D60
Painted
Mounted
Some of your welds look good!
Remeber a grinder and paint will make you the welder you aint... lol
New vehicle purchase, my local county retired a 2015 Grand Caravan. Drove it to the ranch from the county annex. 104k on the odometer, everything works. New Walmart AGM battery installed. I need to replace the passenger side headrest, spill/fill of the transmission, brake fluid and thats about it. Will take a closer look at the oil cooler but I think its probably ok. It will be assigned to one of my kids in the near future.
Not long after I got the Caravan home, check engine came on for a dead O2 sensor on bank 2. I ordered 4 Bosch oxygen sensors, which I think was a mistake. I was pleasantly happy to see that all 4 sensors are the same, but after replacing the one on bank 2 I started to get code P219B, the injector pulse width was consistently low on cylinder 2.
I went ahead and ordered new spark plugs, upper intake manifold gaskets, 1 coil, and just in case a fuel injector. I did find evidence of oil on the upper manifold gaskets, so replacing them was a good thing. I held the fuel injector back. After 30 miles, P219B came up again. I came across a few mentions about several possible root causes to this code, being the lower manifold gasket, fuel injectors, and two references to not use bosch oxygen sensors, and only use NTK sensors.
Okay, so I loaded the parts shotgun again, replaced 3 fuel injectors on bank 2, found further evidence that the lower intake manifold was leaking oil, replaced them, and put in a NTK oyxgen sensor. The OEM oil cooler was dry as a bone. In the process of reassembly the lower intake plenum I stripped two of the plastic bolt holes. Home Depot had 1/4 - 2 inch lag bolts which worked good. I put another 60 miles this afternoon, all readiness monitors cleared and passed Texas emissions testing. Drove another 40 miles back, no CELs.
After these few rounds of troubleshooting over a few weeks, I have to say P219B was one of the tougher CELs I've had to resolve with no real definitive evidence of what it was. I do think it was that the PCM doesnt like Bosch O2 sensors, but the oil on both intake gaskets also made me think there was an air leak somewhere.
The Pentastar is a little finicky, but my faith is holding. Later this week I will do an oil change and trans filter/fluid change. Now to wait on 1 of my 3 kids to get a drivers license and they will have the coolest ex Texas County van around.
When I got home got the oldest son signed up with Vanguard, invest in ETFs in a few days. Had him run the numbers being 18 to see what if could grow to. After that finished our will and scheduled the appointment to be notarized. Went out and taped up the rear Escape. It decided to self eject this weekend.
Window weld is a disappointment, not sure why didn’t stick. The new one is coming with a different type of glue.
I noticed rust bleeding through the rubberized coating of the leading edge of the '79's fuel tank. One of the downsides of a front mounted tank I guess. Wanting to address that, I attached with degreasers, cleaners and a wire wheel. I was surprised to find minimal pitting, a barely affected surface, under the coating. I didn't want to grind away too much, so I treated the minor surface rust in a few spots, primered the rest and finished with many coats of Wurth Stoneguard grey. The original tan is NLA. The Stoneguard is a bit of a pain to apply; spray 20+ inches away, let the solvent flash off, etc. or you wind up with a sticky uncured mess. Great stuff though.
I oversprayed on the heat exchanger guard when my masking blew away, but planned on touching that up a few scrapes on that anyway...and it is the underside.
2006 Hummer H3: replaced RF wheel bearing, LF brake hose, repaired p/s return line and replaced both front CV axles. Stuck in the cycle of replacing cracking aftermarket boots every 8-12 months :rolleyes:
2017 Wrangler: engine oil change and diagnosed bad LF WSS. Part on order
2019 Rogue: engine oil change
2000 Dodge Ram: repaired leaking washer reservoir. This is the second reservoir from a 2nd gen Ram to get a pinhole right here. This time I decided to use my chassis iron.....
......and basically "smeared" over the pinhole. For now it's holding (shrug)
