I wonder what it is, because it smells exactly like soapy water?I got a duckbill kit for my manual tire changer and really like it. Some good tire mounting lube helps a lot, too. Much better than soapy water.
Thats cool.. learn of something new every day. I’ll have to get one of those.I got a duckbill kit for my manual tire changer and really like it. Some good tire mounting lube helps a lot, too. Much better than soapy water.
Ya really need a good conical adapter to center the wheel if you do. Or if you know you only want to regularly do a specific center bore you can just turn a bushing for that ONE size.Thats cool.. learn of something new every day. I’ll have to get one of those.
Had the same car; mine was a 89’ and gold color. Had the iron block and head “tech 4” 4cylinder with cartridge oil filter up inside oil pan. Great car.Repainted the sun bleached body side moldings on the wife's car. Started on the driver's side too. I had painted them at least 6 years ago. This color and finish is a better match than before. The color on the bumpers was always a little different. I'll hit them this time too.
Adulting is a pain in the neck sometimes.Work was really busy today. Shorthanded because 3 guys called out saying they were hung over from football yesterday. Absolutely ridiculous that they allow excuses like that. Even more ridiculous that grown men aren’t responsible enough to know they have a job to go to the next day so they get hammered. But oh well makes me look better because more work for me. Done tires which unfortunately were Michelin so they fought going on and had to cheetah all 4 of them. Then car came back from Friday. One of the express guys had installed a new splash shield underneath and it came down because they put 4 bolts in it but no clips in the middle. Corrected that. Done a few transmission and transfer case services and a coolant flush too. Turned 10.3 hours.
I have a similar HF tire mounter.Spare tire mounted. Getting easier but think I’ll get some spoons to make getting it on easier. Also need to figure out a way to blast air. Beads don’t seem to seal right away but if I pump it up and wait a few it will.
Uh huh.I pre-stretch them with whatever jammed in there before I try to mount them.
If that's not enough, I lubricate (wet) up the inside bead, jam it down on the rim, stretching and manipulating
I had a video on here but it was taken down due to full nudity.
If you went back with plastic parts, you're going to replace them again. Next time buy an aluminum Dorman one. Even the AcDelco plastic parts won't hold up. Eventually you'll have to replace the oil cooler seals, the turbo oil drain seal, and the valve cover, intake and pcv hose.... again. Ecotec 1.4s are permanent coolant/oil leakers.I had to replace the “Coolant outlet” on the Buick in my signature. While I was at it, I replaced the hose connector that snaps into the top of it. For $6 more, I went ahead and ordered it since I figured that it might possibly break taking it off. It didn’t, but it got replaced with the new one anyway.
New outlet, new connector.
For having only 114k WELL maintained miles, I’ve had to do a lot of work on this Buick. (Not a LOT of work, but for 114k, it seems unreasonable.)
I’m just thankful that I have a commercial account with the dealership to save a little![]()
Work that has had to be done on this thing, aside from regular maintenance.
1. Intake manifold / PCV pipe assembly from intake to turbo / valve cover. (Lovely PCV setup in this thing)
2. A/C compressor
3. Thermostat housing
4. Coolant outlet
View attachment 239456View attachment 239457
