Engine attempt #2. I was all prepared with 6013 1/16th electrodes, but chickened out after your wise words and learned how the risk of metal warping was very high. Instead I chopped about 1.5 inches off the center frame cross member. There is 4 inches of 1/4 thick flat bar left. It will be fine. Maybe. If not can reinforce it later.
Then I chopped up the lower radiator fan shroud a bit because this engine is shorter, and the engine fits great. Tomorrow picking up a 90 degree coolant fitting for the lower rad connection. Its really tight between the engine and radiator but it is what it is. I am confidant enough I poured in 3 quarts of sacrificial Rotella T4, then its rehooking things and see if it chooches. ETA this weekend?
