Now that I've got a few years at Deere under my belt, I actually understand what you're measuring here! Bummer for the owner, though. Are you thinking factory flaw of some kind with the low mileage?
Another Toro to rehab and a 6x4 Gator. Pollen everywhere.
The Gator has a nice yanmar engine that I hope runs. It needs more investigation, the fuel cap was missing for an unknown amount of time. It also has a CVT transmission which I find fascinating being paired with a small diesel. The rear 4 tires are chain driven together. The engineers must have had fun designing it.
The Toro does not need alot, tire repair, repaint, maintenance items. it came with a hydraulic cylinder plus lines that used to run an edger. I will reuse it to make a tractor grapple.
I hate small engines. Hats off, sir!!Hauled 12 loads of rock for a new home site today and tinkered with this Husqvarna 142 that I found in a case on the property clean up over the weekend. It was drowning in bar oil and we didn’t know he even had it. So far I’ve found 4 chainsaws and we only knew he had 1.
Took it apart last night and steam cleaned it with my hot pressure washer to get the gunk and bar oil out of everything. The fuel lines crumbled when you touched them and the fuel in the tank was black. Threw a $16 amazon carburetor/fuel line/tune up kit in it and it runs great. Just need to sharpen the chain and I’ll take it back over there to use to cut trees out of the items I’m scrapping. The fuel line outer diameter was larger than original but I compared it to my Stihl saw and it matched. I drilled the hole in the tank out slightly to where it just fit and lubed it up with some caliper grease and managed to wrestle it into the tank.
I wasn’t a fan either in the past but I’ve had to work on some out of necessity in the last year or so and I’m getting better. I hate carburetors with a passion but with these there’s absolutely zero reason to touch one other than to throw it away and put a new one on. This one was almost dead on right out of the box and would’ve worked fine for someone that didn’t know it needed adjusted. About 1/8 turn out on high jet was all it needed.I hate small engines. Hats off, sir!!
It might need a new front diff.Another fantastic day here in Crimetown. Today I planned on changing the gear oil on the 2020 Ram 1500. Easy, right? Each diff has an accessible drain and fill plug. Cool.
I get the front up on ramps to have an inspection. Well, I can see oily dirt residue on the power steering module, makes sense because of the dumb filter location. No worries. Well, why is it went around the axle disconnect? I went to pop it off and of course there is a bolt half way out holding the intermediate shaft to the diff, tighten that in and remove the disconnect. The sealing surface looks fine but I could feel a slight imperfection on the seal. I used a very light skim of RTV and will monitor.
Then I turn my eyes to the CV shafts. Why does the driver side inner tripot wiggle around that much? Well crap. Napa has a new CV shaft on hand and the dealer has a stub shaft in stock if needed. I start the tear down and of course, untouched, the splints are welded with rust. Used some penetrant cycle with heat and a BFH, no dice.
Ill cycle this a bit more this evening and try again tomorrow. Too much to do right now.
On a side note, must have been darn near original fluid, judging by the color of grey the gear oil was.
