CleanSump
Site Donor 2026
My 8 Track was under the dash on the passenger side. I actually moved it from an Isuzu to a Pontiac.
Your youngest daughter is going to be lucky girl (and the envy of the boys for having that truck). I myself have a 93 Silverado and the only way anyone is getting my old girl is when they pry my cold dead fingers off of the steering wheel!My clean one owner 2002 Chevy 2500HD 4x4 with 148K miles
I’m not a mechanic….have a buddy that is..did this yesterday
New Gates water pump T/stat…both belts and tensioners
New heater hoses and SS connections
New fan clutch and fan
Fresh Dex Cool coolant
New plugs and wires
New fuel and air filter
Rotated tires…LT285-75x16s E rated
Runs great….youngest daughter gets it when I’m dead…
Sorry rust belt guys….NO rust !
Passenger side for mine as well. Could have used a more "efficient" method for cassette storage thoughMy 8 Track was under the dash on the passenger side. I actually moved it from an Isuzu to a Pontiac.
Took the +30 minutes to remove all the cosmetic covers, a relay box and the air filter box for access to the back of the headlamp assemblies.Two things that have been bugging me for a while.
First, the LS430 fog lamp took a hit. Unknown how this occurred; I have my suspicions but it's too late for accusations (no, it wasn't my wife; she would have been up front about it). The dealership noticed this when doing their walk-around back in January. I'm hoping that the adjustment and whatever attaches the lamp to the body isn't fubar. In true Toyota fashion, I can't find a parts diagram....yet.
View attachment 326790View attachment 326791
More concerning are the hi-beam bulbs aren't illuminating; both the highs and the DRL's (the 5005 bulbs serve both functions). any suggestions here are welcome.
High beam initial inspection:
The FSM states to do a function check with the hand-held tester (Vetronics). I got thru two menus of the menu tree and there is no function check for the lights. The SW is supposed to be current thru MY 2007.
- Both fog lamps work.
- Both high beams and DRL's don't work.
- High beam indicator on instrument cluster illuminates.
- The fogs turn off when I switch the high beams on.
I did a few visual checks. I do have the FSM wiring diagrams. It appears to be isolated to the high beam circuit; I find it hard to believe that both bulbs would go out at the same time. They were replaced back in October 2024.
My pet orangutan refuses to get his fingers greasyWorking on sparkplug #8 on a Chevy LS engine. It’s the one next to the passenger firewall. It’s easy to get to if you have a pet Orangutang. This my 2nd time I’ve done these plugs and I prefer to take off the passenger front wheel to get to #8.
Getting the boot off is done by resting pliers against the heat shield a using it as a fulcrum to twist the boot off the plug.
Here is a photo looking up from under the truck. There it is, like saying Titan is right near Saturn. I placed the socket and crossover on the plug from down under.
And here is a shot poking under front fender.
I have at socket and crossover on and I use a 1/2 inch ratchet crossed over to the 3/8 inch drive socket to be able to give it the might turn. After 100,000 miles it’s pretty tight.
I got it loose and then the socket slipped off. Enough for tonight.![]()
