So, I got some work done on the Sunfire beater. New headlights in, another drain and fill of the PS reservoir and finally some brake work. I was able to knock the drums off, starting on passenger side. All looked good, wheel cylinder not seized and everything was cleaned and adjusted. I used the trick of putting the back end of a drill bit in the bleeder and gave it a heat/cool cycle. Wouldn't you know it, she worked. Bled that side.
Now the driver side, which is the one giving me grief. As I was knocking the drum off, I found it quite interesting that the shoes wouldn't let go, even though the lip on the drum wasn't that bad. So, once she was off, I noticed a few things missing, that and the wheel cylinder was wet.
I got the bleeder free and then inspected the brake lines. Too rusty to remove and I wasn't about to tear everything off. I gutted the wheel cylinder, buffed the pistons and buffed the inside. Nothing aggressive but enough to clean it up. I cleaned it up and put her back together while clamping both pistons with a C clamps. I bled it and tested the brake pedal. No more leaks.
Tomorrow I will order up some hardware and adjuster parts to fill the gap on what vaporized over the years.
