Rear pads, Pagid on rear of a 2014 Vauxhall Astra.
I hate winding back calipers, especially as it would seem a previous owner put new discs with old pads!
Not a bit of wear or ridge on the discs but on one side there was less than 1mm of pad left, on the other uneven wear and about 6mm of pad
Car did less than 10k miles in last 4 years, I thought caliper on one side was siezed but it wasn’t the piston had just pushed out nearly all the way which meant it was binding up.
One side took an hour to do, the other took 10 minutes
Total work done in last couple of weeks was water pump, thermostat and housing, expansion tank, coolant hoses, oil, oil filter, plugs, air filter, cabin filter, oil cooler.
Under the bonnet it’s basically a Chevrolet Cruze 1.6.
