New battery terminals on a 2014 Grand Caravan
These SAE/DIN/ISO terminals are superior to those pot metal lead garbage ones
I had to get the flange nuts separate at Home Depot
Oil change on my neighbor's 2004 V6 Highlander
It got Total LL 5w30 and a 910s
Should do it nicely for its standard 6m/5k OCI
Most every light bulb on the back end was blown or inop
They use these stupid bulb holders with contacts that were corroded, plus some corroded pins in the connector
I'll wire brush and Deoxit them better next weekend
Plate light was out, screws stripped, had to break the lens off
Now I know why the other side has wood screws holding it in
Someone's been here before
Now I gotta order new lenses and screws
Oh joy
90% of the rear lights now work, the CHMSL melted out
I'm ordering a cheap LED replacement for next weekend
It could really use the headlights polished (and 9012 modded), the drive belts squeak on startup, might adjust them
Power steering is overfilled, I think the intermediate shaft is sticking/clunking
Hatch struts are no longer holding
Probably needs cabin filter, wiper blades, my usually maintenance work
It's developed an appetite for brake fluid, with no leaks
I thought that kinda suspicious, but strange things happen to 20 year old cars with 109,000 on them
I ran the plate number to get the VIN number to get the part # for the plate light lenses
It has 2 open recalls FROM
14 YEARS AGO
It needs a master cylinder rebuild + new booster if fluid contaminated, and a new driver's floor mat with more retention hooks
He's the original owner, how he spaced on these I have no idea
Everything in time
