I am curious to know if a bad EGR gasket can dictate idle issues such as vibration or rough idling? I removed my EGR to clean today, because I will be taking my car to get smogged soon. I noticed there was gasket material missing at the EGR next to the mounting bolt hole and there was carbon all the way down that tear and by that bolt hole. I do have vibration at idle but no codes or vac leaks (brand new engine mounts as wel). I did spray throttle cleaner all over my vacuum lines (doing a once over before smog) and didn’t get a change in idle to verify if I were to have a vac leak.
