In my case I have an Aerostar which takes a Purolater L20195, but my pickup takes a larger L30001, and I found out the bit truck (F700) has an even larger filter that fits the pickup, an L40017. All have the same fitting size and all have the same relief spring pressure (8-11 psi), all have anti drain back valves. Even though the L20195 has a slightly smaller rubber o-ring gasket, I have measured and the L30001 fits the Aerostar gasket mounting surface. The only difference I am aware of besides can size (sure there may be different porosity of paper element) is the gallons per minute flow rate:
L20195 = 3 gpm
L30001 = 4 gpm
L40017 = 7 gpm
Now, as far as I can tell, that means more oil pressure will develop up in the engine where you want it instead of having a restriction just after the pump.
BTW, I got the flow rates for the Wix filters and they are 7-9 gmp for both the 4 and 7 gpms above, Part numbers 51515 and 51773.
