OVERKILL
$100 Site Donor 2021
His last point rings true though, the proper inflation pressure (for load carrying capacity, handling, braking and traction) may not result in the perfect wear pattern, because the wear pattern isn't covered under regulation, it's a function of the tire's design, and if the design is subpar in that area, or if the design compromises wear to excel in those other areas, you are going to observe odd patterns in wear, even though the tire is actually performing as it should.You clearly are more knowledgeable about tire construction than I am, but I can't help but point out that all of the above sound to me like there isn't a one-size-fits-all with tires. This is the point I was trying to prove. Every tire is unique, and every driving habit is unique. Therefore a one-size-fits-all door placard is not to be automatically trusted in absolute.
The other points are the identification of caveats that aren't providing leeway on pressure but rather explaining why some tires may wear differently at the proper pressure than others. This isn't a rubber stamping to try and rectify that wear pattern via manipulation of pressure, which will cause changes in performance in other areas, but simply an explanation of why that phenomenon may be observed.
