As a wee grasshopper, I used to watch my Dad rebuild 50's and 60's era engines. These engines were run out in as little as 50K miles. The bearings were worn, cranks scored, rings stuck and broken, and the cylinders always needed boring. This is all in engines with well under 100K miles, mind you, and they all had regular maintenence. It's just that the old filters and oils were not as good as what we have today.
I think most had filter cannisters mounted on the top of the engine, and I'm sure the filter media didn't work very well. My point is, great strides are being made in lubrication and filtration today. I think just about any of todays filters will remove the particles that cause engine wear, and an oil change will remove the rest.....
