How about a big cement patio? I'm tired of power washing every spring
From what I have read about Wet and Forget it might work... I just power washed my driveway a month ago and will spray it with Wet and Forget just to help keep it cleaner longer and again in a few months going into winter... My driveway faces north and half of it is in the shade for most of the winter...this stuff might help...How about a big cement patio? I'm tired of power washing every spring
.. same chemical in the pool section of Walmart "dimethyl benzyl amoninum chlorides" so refill your sprayer with "HTH Algae Guard".
Also, I mix it with liquid pool chlorine 50/50. It is far more effective and lasts just as long.
I am already seeing good results on the siding....From what I have read about Wet and Forget it might work... I just power washed my driveway a month ago and will spray it with Wet and Forget just to help keep it cleaner longer and again in a few months going into winter... My driveway faces north and half of it is in the shade for most of the winter...this stuff might help...
Just be careful mixing other cleaners with Clorox, it can create a powerful dangerous gas. never do it indoors unless you know what you are doing.Make enough 30 Seconds cleaner to clean your house 2x with a gallon of pool chlorine (5-6$ at Walmart) (use 1 cup/gallon) and about a tsp of Dawn per 1 gallon batch. I have 2 of the 30 Second sprayer jugs that I keep re-using.
I think my 30 Seconds cleaner hose sprayer bottles are more like 3 quarts, but I still eyeball in a cup of pool chlorine and a tsp of Dawn per jug. I need about 2 jugs per side, so a gallon of pool chlorine gets me ~2 cleanings (I pour a bit in my showers and toilets once in a while too - holy cow will it clean a shower floor). I am doing spring and late fall in my climate. So much rain and humidity here this summer it looks like my house got skipped this spring, though it didn't.
As mentioned several times already, 30 Seconds cleaner is truly just a mixture of bleach (stronger than Clorox, hence using pool chlorine - same chemical composition) and a surfactant agent (soap like Dawn) to get it stick to the house just long enough to kill the algae and help with rinsing dirt/dust/algae debris.
It does help on the concrete driveway and sidewalk, though it doesn't get it looking new. I also really only use the little remnant on the driveway and sidewalk out of the last mix. I am not overly concerned that the driveway is not gleaming white. If I used more, it would probably clean more.
Good call out. There used to be a Dawn that was marked "safe for use with Bleach" but I think California threatened to sue them into oblivion because California thinks people are stupid* and don't read - hence the Tide Pod yum yum idiocy of 10 or so years ago. I may be wrong on the California part, but I don't think I am. Laundry soap will also 100% work, as should Dawn as it does not contain ammonia. I certainly mix it outside, not just as a precaution for fumes as just 10% sodium hypochlorite fumes alone will run me out of the bathroom when I pour it in the tub or toilet, but also because I don't want to splash any 10% bleach onto my floor or my clothes etc.... - always puor some into a container outside when I go to tsupersanitize inside and I pretty much hold my breath while carefully carry said container of super bleach into the house.Just be careful mixing other cleaners with Clorox, it can create a powerful dangerous gas. never do it indoors unless you know what you are doing.
I do use bleach in house wash sprayer in the past. But I dont mix it yet you are doing it right, others need to be aware of things mot to mix.
https://draxe.com/health/dangers-of-bleach/
https://doh.wa.gov/community-and-environment/contaminants/bleach-mixing-dangers
