I agree. You could use either, but if you have a choice locally, I'd suggest a G-05 (Zerex G-05 if available) or Honda, Toyota, or Nissan long life antifreeze/coolant. These four brews qualify as hybrid type - and they're all good in virtually any cooling system. They may differ in marker dye color form what's currently installed, but the specific color is irrelevant - the dye is only added to help trace exterior coolant leaks. (There are green conventionals, green "dexclones", orange DEX-COOL, orange G-05s, yellow G-05s, and the Japanese hybrids - essentially the same - are blue form Honda, red from Toyota, and green from Nissan. Crazy, yes?) Just be sure to do several distilled water flushes until what drains comes out water-white clear, and use distilled water to dilute. Hope this helps alleviate your concerns.
